2007 gmc acadia
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=93972
Printed Date: April 18, 2026 at 6:02 AM
Topic: 2007 gmc acadia
Posted By: prewired
Subject: 2007 gmc acadia
Date Posted: May 16, 2007 at 1:33 PM
I have a 2007 GMC Acadia that I want to install 2 - 12" MTX subwoofers with 2 - MTX Amplifers. The vehicle has a Bose Surround Package with an amplifer and subwoofer that came stock. Are there any RCA outs for the amps, and is there a way to locate them without removing the dash? I can't seem to find a wiring diagram. Any help would be greatly appreciated. Thanks in advance.
Posted By: sqsq
Date Posted: May 17, 2007 at 2:20 AM
I have never encountered a stock system (bose or otherwise) that had amp preouts.  If you're stock system is factory amped, the amplifer will be recieving a low-level signal from the head unit but that low lever signal is being transferred via speaker wire, not RCA's.  In order to hook up the subs you'll need to purchase a line out converter to give you a sort of makeshift set of RCA preouts (or, if your MTX amps have high-level speaker inputs you could use those)  You may want to consider replacing the stock head unit with an aftermarket one to get better bass and better bass control.  I know you probably don't want to give up the factory Bose head unit, but I've replaced those before, and replacing it is something you needn't worry about (as far as sound quality is concerned)so long as you replace it with a good SQ deck such as Eclipse or Alpine.
