bridged or separate? dvc
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=94307
Printed Date: March 26, 2026 at 8:42 AM
Topic: bridged or separate? dvc
Posted By: mr^man
Subject: bridged or separate? dvc
Date Posted: May 28, 2007 at 11:42 AM
Hi guys! In case you can't tell, I'm new in here ;)
Okay, what I have:
- 1 10" Alpine S-type, dual 2-ohm
- Jensen XA2125 amplifier (175W x 2 @ 2ohms, 350W bridged [I'm assuming @ 4ohms], RMS ratings)
At the moment, I have the sub in a 1-cu.ft. sealed box, wired in series for 4ohms, bridged.
would it make any difference whatsoever if I wired the coils separately to each channel, or am I better off leaving well enough alone?
mr^man
Posted By: audioman2007
Date Posted: May 28, 2007 at 11:46 AM
Yes it would make a difference. Since your sub is a dual 2 ohm coil and your amp can put out 175 per coil at 2 ohms. Your amp will put out more power in 2 ohms than it will in 4 ohms. You subs will pound harder but wont be as clean as 4 ohm. Basically what you can do is just try both ways and see what you like more. Just make sure you dont set the gains up too high in 2 ohm or you could ruin your amp.
Posted By: DYohn
Date Posted: May 28, 2007 at 11:58 AM
Ah, no, that is incorrect.  There is no difference operating a stereo amp bridged into 4-ohms or in stereo at 2-ohms.  This will result in exactly the same power output.
Posted By: mr^man
Date Posted: May 28, 2007 at 12:20 PM
Thanks guys... and DYohn, that's what I thought... just wasn't sure if I should trust my gut on that one, is all...
Mr^Man
