port length and box tuning
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=94777
Printed Date: May 08, 2026 at 9:03 PM
Topic: port length and box tuning
Posted By: jayjae
Subject: port length and box tuning
Date Posted: June 14, 2007 at 10:03 AM
i went through the calculations and for the recommended port length in order to reach my desired frequency it gave me a long port like 12 inches. i was wondering if it was at all possible to plit up that length into 2 ports that are 6 inches long and would the box still be tuned to the same frequency.
Posted By: DYohn
Date Posted: June 14, 2007 at 11:06 AM
No, that is not how ports work.  If the required length is too long to fit into your enclosure you can use bends to get to the required length, or use a smaller port diameter (which introduces other issues.)
Posted By: jayjae
Date Posted: June 15, 2007 at 7:19 PM
i want to split it into two ports because it will look better. but i will not do this if it effects the tunes frequency. so if it would effect the tunes frequency let me no please
Posted By: stevdart
Date Posted: June 17, 2007 at 8:15 AM
The opening area of the port is what is important here.  If it's a round port, say 3" diameter, the tuning of the box is a calculation of opening area (diameter) and port length.  If you want to use two ports for aesthetics, and you want both ports to be 3", each one will have to be twice the length of the single 3" port.  You would have to drop the opening area in half on each port if you want the port length to remain at the length in your specs.
