Install extra batt need wire diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=9485
Printed Date: May 06, 2026 at 4:39 PM
Topic: Install extra batt need wire diagram
Posted By: rk.mendoza
Subject: Install extra batt need wire diagram
Date Posted: February 13, 2003 at 5:36 PM
Hey guys I want to install a new batt in my 2002 ford explorer so I can run the audio video and well my amps and everything. Do you know how to do it and if you do, any diagrams on how to do it...
Ronnie E Mendoza
You can do anything you put your mind to.
Posted By: Big Purds
Date Posted: February 13, 2003 at 5:57 PM
are you going to wire in an isolator to isolate the two batteries from eachother? (this prevents the stereo battery from killing your car battery if you want to run your setup while the vehicle is off, so you can always start your vehicle without difficulty)
personally, I have two batteries, but I didnt isolate them...however, I am aware of my stereos current draw potential and I always keep that in mind when I am playing my stereo while the car is off...
which setup will you be going with?
Posted By: wvsquirrel
Date Posted: February 13, 2003 at 10:48 PM
read all about it...
https://www.the12volt.com/installbay/display_topic_threads.asp?ForumID=2&TopicID=8915&PagePosition=3#thread
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
Date Posted: February 15, 2003 at 5:07 PM
Ok I will try an isolater but I need help on how to wire it pictures or drawings will help allot...
Ronnie E Mendoza
Posted By: lagatbezan
Date Posted: February 16, 2003 at 11:41 AM
here is a wiring diagram for hooking up a isolator.. i use the sr200 by stinger and it works perfect!
https://www.stingerelectronics.com/sting_products/SR200%20multiple%20batt%20DIAGRAM.pdf
Date Posted: February 16, 2003 at 3:41 PM
Thanks man I will see if this helps me..
Ronnie E Mendoza
