orion xtr pro 1000
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=94875
Printed Date: May 08, 2026 at 9:44 AM
Topic: orion xtr pro 1000
Posted By: crk245
Subject: orion xtr pro 1000
Date Posted: June 17, 2007 at 7:43 PM
Hey guys
Im about to do an install on my little bros car.  Im bpitting together a pretty basic system.  to JL 4ohm 12's and an old school Orion Xtr pro 1000.  My question is its been so long since I have installed one of these amps im not sure wich channels I should use to bridge the amp.  If anyone has aby info on on of these old babys please let me know.
Here is what the plug reads
Rem  +   +   -   -
C
Posted By: i am an idiot
Date Posted: June 17, 2007 at 8:38 PM
If you have an ohm meter, there will be 2 speaker terminals that are shorted together. It will be the positive of one channel and the negative of the other. When you find these 2 wires, the other wires will be the bridged wires. I.E if right - and left + show a dead short, the bridge wires will be right + and left -
Posted By: lspker
Date Posted: June 17, 2007 at 9:42 PM
Is that not a mono block?
Date Posted: June 17, 2007 at 10:37 PM
I just looked at the layout of the plug that he posted in his original post and Yes it does look like a mono amp.
Posted By: crk245
Date Posted: June 18, 2007 at 10:50 AM
I think you might be right...
Posted By: crk245
Date Posted: June 18, 2007 at 10:53 AM
here is some info:
Product Details and Features
Key Features
Amplifier Type
Mono Channel
Bridgable
Bridgable
RMS Power at 4 Ohms 250 W x 1
RMS Power at 2 Ohms
500 W x 1
So what is the best way to hook up the two subs?
Posted By: hustlin247
Date Posted: June 18, 2007 at 5:49 PM
well, it looks like you can only go as low as 2ohm's on that amp.
And if you have dual 4ohms on your JL's then really, the only way you can safely hook it up is series-parrallel.
Like the second diagram on https://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42 this page.
You didn't specify that your subs were DVC but the fact that you are asking how to wire your subs makes me assume that they are.
If your amp is in fact 1ohm stable and you have dual 4ohm coils than you can wire all four coils parrallel and get the most out of your brother's amp and speakers.
'94 Ford Explorer / Kenwood KVT-815DVD / RF Power T1682C 6x8 (all doors) / RF Power T10001 / 12" Kicker L5 (x4) / Optima Yellow Top Battery
