accessory wire in chrysler 300
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=95027
Printed Date: March 26, 2026 at 11:21 PM
Topic: accessory wire in chrysler 300
Posted By: nighttrane
Subject: accessory wire in chrysler 300
Date Posted: June 22, 2007 at 3:39 PM
I have a 2005 Chrysler 300 Touring that I have installed an aftermarket cd player in. The deck is completely hooked up except for the accessory wire, my problem is I can't find an accessory wire from the factory radio location. Any help to locate it would be greatly appreciated.
Posted By: i am an idiot
Date Posted: June 22, 2007 at 4:27 PM
There is no accessory wire in the harness for the factory radio.  It turns on via a DataBus wire.  There are several companies making harnesses for these cars.  They are not cheap, but they take the data from the car's computer and give you a switched output.
I am sure somebody else can give you a part number and manufacturer for the harness.
