1993 lexus gs300 stock amplifier info
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=95340
Printed Date: May 08, 2026 at 3:19 PM
Topic: 1993 lexus gs300 stock amplifier info
Posted By: Melted Fabric
Subject: 1993 lexus gs300 stock amplifier info
Date Posted: July 04, 2007 at 9:04 PM
I had my brother buy a Volfenhag ZX4710DVX - 10" Aluminum Subwoofer to replace the stock subwoofer that was in there, but had unfortunately blown.
I go to his place today to look at the new Volfenhag that had just come, and it is a 4-OHM Dual Voice Coil setup with 800W Max.
I was planning on doing a switcharoo and just swap out the old, and plug in the new, but I cannot get any information on the stock amplifier to see if this is possible.
Anyone familiar with the stock amplifier and it's potential with non-stock subwoofers?
I have not failed. I've just found 10,000 ways that won't work.
When you do not know what you are doing and what you are doing is the best -- that is inspiration.
Posted By: i am an idiot
Date Posted: July 04, 2007 at 10:26 PM
     The amp could care less what kind of speaker it is driving as long as it is not run below it's minimum ohm load.  All you need to do is check the impedance of the factory sub and do not go below that number.  If it has an open voice coil and has no markings on it,  wire the coils of your woofer in series and go with it.  I am sure the amp will handle the 8 Ohm load.
Date Posted: July 05, 2007 at 12:13 AM
Cool, I appreciate that. I really do.
I focus more on fabricating that I do the technical subwoofer setups, for now at least.
Thank though, I will wire it with a series style.
