03 suburban bose noise
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=95353
Printed Date: May 08, 2026 at 3:19 PM
Topic: 03 suburban bose noise
Posted By: KarTuneMan
Subject: 03 suburban bose noise
Date Posted: July 05, 2007 at 12:44 PM
Had a customer in the shop to day. ALL stock....not one piece of after market anything. The wife drives the rig. For the last 6 months the rig has developed one hell of an acoustical tachometer. The stealership has replaced the alternator, the guage cluster (cause the whine played with engine rpm. NOW they tell the guy.....it's the amp!! Yet, shut the car off, no noise. To me this eliminates the amp. I could be wrong. with the key on, engine off, open the door and set off the door dinger key reminder.....HOLY cow, what an awful noise. NOW the dealer wants to replace an 800.00 bose amp..... ha ha!
Just wanted to get some opinion/ideas. I am not doing any work on the unit......unless I replace ALL the Bose crud.
Posted By: DYohn
Date Posted: July 05, 2007 at 1:15 PM
It could be the amp and if it has lost its internal ground plane would only make alternator whine when the engine was running.  It could also be anything i the ignition system, including the ECU, spark plugs, plug wires, distributor cap...  $800 for the OEM amplifier is a common dealer (gouge) price.
Posted By: haemphyst
Date Posted: July 05, 2007 at 1:53 PM
KarTuneMan wrote:
stealership
That's funny... Can I use that? posted_image
Date Posted: July 05, 2007 at 6:42 PM
haem..... feel free. It's the truth. (stealership I read here on the 12volt)
acoustical tach......sounds better than engine whine!posted_image
