more ohms or less ohms
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=95833
Printed Date: April 25, 2026 at 2:09 AM
Topic: more ohms or less ohms
Posted By: chrisdesousa
Subject: more ohms or less ohms
Date Posted: July 23, 2007 at 3:20 AM
I have got 2 12" star sound 1500W subs and was wondering if it's better to wire them using the max amount of ohms your amp can handle or or is it better to wire them using less ohms? In other words is having more ohms better than having less ohms?
------------- Go BIG or go home!!
Posted By: haemphyst
Date Posted: July 23, 2007 at 8:29 AM
If you wire for HIGHER ohms, (that is, less load) your amp won't make as much power, but it ALSO won't make as much distortion, or heat, and the damping factor will be better on it. Those are all good things in my opinion, with the exception of the "lack of power".
Keep in mind, that if you have an amplifier, connected to X woofer, it will make XdB. If you double the ohms (which is half the load) you will ONLY LOSE 3dB! Hardly even noticeable, and unless you are in competition, it WON'T be noticeable, especially in a daily driver.
------------- It all reminds me of something that Molière once said to Guy de Maupassant at a café in Vienna: "That's nice. You should write it down."
