setting 2 500/1 amps for 2 12 w6’s
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=95880
Printed Date: April 24, 2026 at 3:41 AM
Topic: setting 2 500/1 amps for 2 12 w6’s
Posted By: pman187
Subject: setting 2 500/1 amps for 2 12 w6’s
Date Posted: July 24, 2007 at 5:29 PM
I have a 500/1 amp running 2 12w6's right now, and i recently purchased another 500/1 amp from one of my buddies so that i will have 1 amp for each sub.  I was wondering if someone could help me out with the wiring for the amp and I also need help with setting the amp for each sub.  Thank you very much.
Posted By: derder1984
Date Posted: August 05, 2007 at 6:31 PM
How are you running it now the subs now? Is it 2 dual 4 ohm 12w6 subs wired in parellel to one termminal dropping it to 1 ohm to the amp? I would say the best way, if it isnt too hard for you is to have the a single box with dual ports and each sub is in its own seperate compartment. Then running each to its own amp.
