wiring subwoofers
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=95946
Printed Date: April 22, 2026 at 4:05 AM
Topic: wiring subwoofers
Posted By: slatham
Subject: wiring subwoofers
Date Posted: July 27, 2007 at 2:10 AM
I have 2 kicker 12" L7 subs that are rated at 750rms watts each (375rms for each voice coil). They are DVC. They are 2 ohm subs. I was looking at your wiring diagrams for subs and found that you get a 2 ohm load if you wire the voice coils in series and the speakers in parallel. I'm going to use a kicker mono amp rated at 1500rms watts. This will work, right? Also i was wondering what kind of wires i should run from the amp to the subs and like between the voice coils and everything.
Posted By: stevdart
Date Posted: July 27, 2007 at 5:52 AM
Yes, that would work just fine.  Use standard 14 guage speaker wire for the wiring.  Split the paired wire and use one strand to connect voice coils.  A lot of people will solder the wire to the speaker terminals but I like to disconnect quickly and cleanly when I want to, so I use disconnects and crimp / solder the wire to those.  Get some that fit the terminals snugly.
