subs in house
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=96366
Printed Date: April 26, 2026 at 9:28 AM
Topic: subs in house
Posted By: bill1990
Subject: subs in house
Date Posted: August 13, 2007 at 1:29 PM
Is it possible to run a system off of a dvd player?
Posted By: haemphyst
Date Posted: August 13, 2007 at 3:52 PM
Define "system". If you are asking if you can just "plug in", then no, you have to have amps, power supplies, cables... All of the associated things in a car, must also be present in the house.
Otherwise, a home system is NO DIFFERENT WHATSOEVER than a car system, except you plug in to 120V, rather than 12V. It still uses sources, pre-amplification, crossovers, drivers, amplification... Everything is identical.
Posted By: i am an idiot
Date Posted: August 13, 2007 at 4:13 PM
Is it a DVD player with a built in surround system with amplified outputs for subwoofers along with 5 other speakers?
