jl 10 w3 hooked up to jl 250/1
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=96570
Printed Date: April 16, 2026 at 6:21 PM
Topic: jl 10 w3 hooked up to jl 250/1
Posted By: jake_evans420
Subject: jl 10 w3 hooked up to jl 250/1
Date Posted: August 22, 2007 at 8:18 AM
i have them all hooked up and i cant figure out whats wrong its just not working and the amp is getting power idk i hope one of you guys can help me out if you need any more info just let me know
Posted By: StealthEs
Date Posted: August 22, 2007 at 9:28 AM
I would start by checking the RCA make sure they are connected at the radio properly. You might have a bad set of rca's. Run a new set as a test, see if that helps any. If those dont help, get a small speaker you might have around. Use that as a test speaker. Unhook the sub from the amp and use you test speaker to see if that gets power.
------------- Cris
Posted By: dpaton
Date Posted: August 22, 2007 at 12:36 PM
Check the remote lead too. I spent an entire weekend troubleshooting something similar for a friend that turned out to be a broken blue wire under the carpet. Annoying, but easy to fix.
------------- This is not a sig. This is a duck. Quack.
Posted By: jvillefinest
Date Posted: August 22, 2007 at 3:02 PM
take a battery...usually a drill battery and touch it to the possitive and negative wires comming from the sub to the amp...try it one way then switch the wires touching the battery to the other side...if it moves in and out you can completely take that out of the problem side of the list.
------------- 2007 Acura TSX
SQ setup in the works
