97 2.2 cl radio removal
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=96610
Printed Date: April 30, 2026 at 6:16 PM
Topic: 97 2.2 cl radio removal
Posted By: jaybird2020
Subject: 97 2.2 cl radio removal
Date Posted: August 23, 2007 at 2:02 PM
Hello everyone getting ready to do a radio install on a 97 2.2 cl acura. has anyone know how to get the radio out (fact) any help would greatly appreciated.
Posted By: dwarren
Date Posted: August 23, 2007 at 2:07 PM
I believe they are similar to accords, start with two screws in the center console box/arm rest, two to three under the cup holder area, then that whole assembly should slide back you may want to lift it over the e-brake, but not necessary) , there will be one screw behind the ash tray, and then I use a plastic panel tool to remove the bezel around the radio.
Date Posted: August 23, 2007 at 2:16 PM
yeah, it does look the same didnt want to break anything thanks for the help
