2 pdx amps to 3 subs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=96628
Printed Date: May 01, 2026 at 2:29 AM
Topic: 2 pdx amps to 3 subs
Posted By: mikejc
Subject: 2 pdx amps to 3 subs
Date Posted: August 24, 2007 at 6:35 AM
Is it possible to power three 12" DVC 2ohm subs with one PDX 1.1000, and one PDX 1.600 and get the same power output on all three subs. I already wired it up with the 1000watt amp powering 2 subs at a 2ohm load, and the 600 watt amp powering the third at a 4ohm load. The sub wired to the 600watt amp was hitting alot harder then the other two. Is there any way to get them to all hitt the same? oh yah the box has no dividers in it.
Posted By: haemphyst
Date Posted: August 24, 2007 at 7:28 AM
No. Looks like new woofers are in order.
Posted By: i am an idiot
Date Posted: August 24, 2007 at 7:40 AM
Since you already have the equipment and it is already installed, try turning the gain down on the 600 so that the movement of that woofer matches the movement of the other 2.
Posted By: jvillefinest
Date Posted: August 24, 2007 at 1:30 PM
i dont think its possible to make them exactly the same but i know if you do alot of tuning you can get it close. because a friend of mine did this with 3 10w7s with a jl1000/1 and a 500/1.  sounded great
2007 Acura TSX
SQ setup in the works
