amp draining my battery
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=96978
Printed Date: May 07, 2026 at 3:16 AM
Topic: amp draining my battery
Posted By: killa101
Subject: amp draining my battery
Date Posted: September 08, 2007 at 4:19 PM
My battery kept dying and after testing out everything i think i narrowed down the problem. i think that my amp is broken, like a relay inside it or something. what is happening is that i will run my system but when i try to start my car after it rests it doesn't start. i know that it isn't my alternator or battery so the only thing i can figure is my amp is staying on somehow. i want to know if there is anyway i can keep my amp from draining my battery when my car is not on. i was thinking of putting in a relay or something but i can't find one that is big enough to put in the power wire. do you guys have any ideas of how to fix this problem???
Posted By: KarTuneMan
Date Posted: September 08, 2007 at 6:35 PM
Unhook the power wire from the amp.....see if the problem remains.....if it does....your amp is not the cause, and look elsewhere!
Posted By: killa101
Date Posted: September 08, 2007 at 7:26 PM
i already tried that... i also hooked up another amp for a while and the problem stopped too. that way i knew it wasn't the wiring.
Posted By: Alpine Guy
Date Posted: September 08, 2007 at 8:55 PM
What amp are we talking about here? And what car?
------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
Posted By: killa101
Date Posted: September 09, 2007 at 12:16 AM
it's an audiobahn monoblock amp in a 96 chrysler cirrus. i have 4 gauge wire running to the amp.
Date Posted: September 09, 2007 at 9:55 AM
Have you tried leaving the amp hooked up, but not running the stereo for a day. It could be possible that your amp draws a lot more power than your alternator can supply so it slowly drains from the battery until you turn the motor off resulting in not enough juice in the morning.
Posted By: killa101
Date Posted: September 10, 2007 at 2:40 PM
i thought of that but i didn't really think that was the problem. the reason is because i used to have another amp that i ran for a couple of months and i never had a problem with that amp. it was only 1200w and not 1600w like the audiobahn but the 1200w amp was a diamond audio. i still think that it could be the problem but i'm pretty doubtful that is the case.
Posted By: aznboi3644
Date Posted: September 13, 2007 at 5:36 PM
haha....1600 watt audiobahn amp??
prolly puts out more like 600 watts.
Sorry but Audiobahn is very poor quality and usually highly overrated
Posted By: jmelton86
Date Posted: September 13, 2007 at 6:49 PM
Agreed. The DiamondAudio 1200 watter has got to put out more power than the Audiobahn '1600' watter. You would think it would use more power. ------------- 2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
Posted By: killa101
Date Posted: September 15, 2007 at 2:24 AM
i know that the audiobahn sucks which is why i came to the conclusion that it wasn't my alternator. i knew that if the diamond amp wasn't straining my alt too much than my audiobahn shouldn't have a problem. that is why i'm thinkin that it is the amp and not the alt.
Posted By: DYohn
Date Posted: September 15, 2007 at 9:21 AM
New amplifier. ------------- Support the12volt.com
Posted By: the12volt
Date Posted: September 15, 2007 at 9:33 AM
If you're determined to stay with the Audiobahn amplifier, add a high current relay ( PAC-200 ) to its main power lead to insure it is not drawing any current when the system is off. ------------- the12volt • Support the12volt.com
