double din in neon?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=97112
Printed Date: April 18, 2026 at 2:00 AM
Topic: double din in neon?
Posted By: eldon
Subject: double din in neon?
Date Posted: September 13, 2007 at 1:30 PM
Anyone ever put a double din in a dodge neon?
Pics? suggestions?
Posted By: audiomaninc
Date Posted: September 13, 2007 at 1:40 PM
What year neon?  It can be done with little modification.
2003 Dodge Neon R/T
Alpine CDA9813, RF T2000.1bd, RF T162S, RFT142C, RF T600.4, RF T215D4
140.7 @ 28Hz
Posted By: eldon
Date Posted: September 13, 2007 at 1:52 PM
It's a 04 or 05, can't remember.
SX series I think is what it's called.
Posted By: xtremej
Date Posted: September 13, 2007 at 4:41 PM
Theres room, it is do able. try getting on a neon forum some neon nut will have pics of one. You ever do any fabrication and or fiberglass work?
Date Posted: September 14, 2007 at 9:56 AM
Alright...there's plenty of room to do this, you'll just have to be careful with the dremel or you'll be replacing the center stack trim ring.  The stock radio is a 1.5 DIN with rounded edges.  You can cut .25 DIN above the radio and .25 DIN below the radio and you'll be fine.  On the bottom it'll take you right to the top of the small pocket/defroster switch/power outlet assembly.  On the top it'll take you to just a hair below the HVAC controls.  Good luck and make sure to post pictures!
2003 Dodge Neon R/T
140.7 @ 28Hz
