LOC, oem system, a.m. amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=9716
Printed Date: May 04, 2026 at 9:50 AM
Topic: LOC, oem system, a.m. amp
Posted By: davejax
Subject: LOC, oem system, a.m. amp
Date Posted: February 18, 2003 at 9:20 PM
i would like to connect my sub and amp to my OEM sound system.   the HU does not have pre amp outs, thus i could see ways to connect it
1LOC,  splice into the + and - of the rear left and right and go thru a LOC which goes to the amp then to the sub
2a high level input amp, splice the + and - of the rear left and right directly into the amp
my question is what is the difference in the 2 ways?   i know if i use method 1 that my rear speaker levels (and my front speakers too?) will drop but how much, and is it according to how hard the amp is driving?   if i use method 2 will i fry my OEM HU?  and in turn will that affect the dB level of all of my speakers? (front and rear)   does the LOC isolate the 'pull' the aftermarket amp has on the OEM amp?
a third option mentioned to me is to use a multi channel amp.  take the rear feeds into the amp and use ch1 and ch2 for the rears and ch 3 and 4 bridged for the sub, but then i am spending a lot more money and doing a lot more wiring.
Posted By: esmith69
Date Posted: February 19, 2003 at 4:54 PM
What kind of vehicle do you have?  And does it have a "premium" sound system (i.e. Infinity, Bose, JBL)?  If connected properly the high level inputs to the amp should not create an extra/excessive load on the factory head unit. However it depends on what type of factory system is already in the car.
