winisd, maximum spl
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=97397
Printed Date: March 27, 2026 at 11:15 AM
Topic: winisd, maximum spl
Posted By: badasschevillac
Subject: winisd, maximum spl
Date Posted: September 24, 2007 at 4:17 PM
i built a box for 2 15" l7's, 10.5 cu.ft. tunned to around 35 hz. my question is on the transfer function magnitude screen, if u scroll down and select maximum SPL and then find the point that is ur maximum SPL, will that be ur actual maximum SPL? cuz i found the max and it is around 131 db at i think around 49 hz, i thought that these subs would perform a little better than this with the box that i have designed for them? any help would be appreciated! thanks
Posted By: aznboi3644
Date Posted: September 24, 2007 at 4:39 PM
that max spl is not your real max spl...its just a general idea
WinISD has no way of knowing your vehicle's specific transfer function, box placement, and many other variables
Date Posted: September 24, 2007 at 4:43 PM
thanks, man i was hoping that wasnt the true max spl. thank you
