settings on digital alpine amp?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=97597
Printed Date: March 25, 2026 at 12:04 PM
Topic: settings on digital alpine amp?
Posted By: wildcatjay
Subject: settings on digital alpine amp?
Date Posted: October 01, 2007 at 6:54 PM
I have an mrd-m501 digital amp and 2x type r alpine 12 in subwoofers in a qlogic banpass box, I am knowledgeable on the conventional amp however this amp has many many digital settings is anyone familiar with this set up? if so what should my setings be at? I have the mono amp ran into 2x dual voice coil alpine subs
OK So Im new at this work with me
Posted By: tcss
Date Posted: October 01, 2007 at 7:13 PM
What is the preamp output voltage of your head unit.
There is no such thing as free installation!
Date Posted: October 01, 2007 at 7:40 PM
Im not sure its a sony explode 52x4  but I'm not sure what the out put range is, it has an  amp adjustment  but it dosent specify the levels of adjustment jsut low to high. how do I find out?
Posted By: tcss
Date Posted: October 01, 2007 at 7:57 PM
Go on Sony's websight and punch in the model #.
Date Posted: October 01, 2007 at 10:04 PM
Im sorry for the huge thread but if i expect help i should post all possible info right?
head unit:
Product Features
  • Detachable front panel CD player with bright blue/white screen, red control buttons
  • Compatible with CD-R/RW discs
  • 4-channel amp (17W x 4 channels); subwoofer pre-amp outputs
  • SSIR-EXA tuner with 18 FM and 12 AM presets
  • Includes case for detachable front panel
Technical Details
  • RMS power output: 17 watts
  • Peak output: 52 watts
  • Preamp voltage: 2 volts
  • Preamp outputs: 2
  • AUX input: No
  • Display color: Blue/white
  • Sound processing: EQ3
  • Wireless remote: No
  • Wired remote: No
  • Changer control: No
  • Detachable face: Yes
  • Tuner type: SSIR-EX
  • Presets: 18 FM, 12 AM
  • Seek/Scan: Seek
  • Satellite Radio ready: No
  • Anti-Shock memory: No
  • CD text: No
  • CD-R/RW playback: Yes
  • MP3 playback: No
  • WMA playback: No
  • Warranty: 1 year
  • What's in the box: Main unit, parts for installation and connection, front panel case
amp:
Features
Inputs and Outputs Notes
Specifications
Features
V12 AccuClass-D Mono Amplifier: The V12 AccuClass-D amplifier design allows it to deliver massive power without correspondingly huge current draw. This amplifier's true digital design keeps the signal purer and makes the amp extremely efficient. V12 AccuClass-D amps use digital signal processing to provide time correction and other sophisticated controls, all controlled through the Alpine Digital Control Center located under the top-mounted access panel.
Hood: The amplifier has a hinged brushed aluminum hood that flips up to reveal the control panel and LCD display. The control panel consists of six buttons: Display, Mode (up), Mode (down), Enter, <, and >. These buttons are used to navigate the menu that includes all the adjustments on the amp (input level, crossover, EQ, time correction, phase, etc). When closed, the LCD display is visible through the smoked plastic window. Two Allen-head screws (supplied) secure the hood in the closed position.
Display Control: The MRD-M501 features a 5-digit information display that allows you to check the operational status of the amplifier. By pressing the Display button, you can cycle through the following readouts: Voltage (supply), Current (draw), Internal Temperature (Fahrenheit), and Internal Temperature (Celsius).
Terminal Cover: The amplifier is equipped with a silver brushed aluminum terminal cover that can be attached to the front panel to improve appearance after the amplifier has been installed. The terminal cover hides power, signal and speaker wires, and secures to the amplifier via two Allen-head screws (supplied).
Verification Certificate: The amplifier comes with a certificate that informs you of the total RMS output of the particular amplifier. It lists the model number, serial number, test date, and the test conditions (voltage, impedance).
Bass Engine DSP: The MRD-M501 uses digital signal processing to offer several sophisticated Bass Engine controls without signal loss or sound degradation. The Bass Engine features include:
  • Digital Time Correction: Time correction allows you to time align this amp with others in the system. This is particularly useful to maximize SPL if there are multiple subs and sub amps. The adjustment range runs from 0-10ms in 0.1ms steps.
  • Digital Parametric Equalizer: A fully adjustable parametric EQ is built into this amp. The center frequency is adjustable from 30 to 160Hz in 1/12 octave steps. The Q value of the EQ curve is selectable between 0.5, 1, 2, 3, 4, and 5. The EQ level is adjustable from -12dB to +12dB in 1dB steps.
  • Built-in Variable Crossover: The built-in low-pass crossover is adjustable from 30 to 200Hz in 1/12 octave steps with a selectable slope of 12dB/octave or 24dB/octave.
  • Subsonic Filter: The subsonic filter is used to filter out low frequencies that you cannot hear but can "rob" power from the amplifier. The crossover point is variable between 15Hz and 50Hz in 5Hz steps, and can be switched on or off.
  • Bass Compensation: The Bass Compensation circuit is used to enhance low-end bass definition. When engaged, the Bass Compensation circuit provides bass with sharp auditory impact, even with a small diameter woofer. Once turned on, you can select the Bass Compensation level that best suits your desired results: Bass Comp 1, Bass Comp 2 or Bass Comp 3.
  • Phase Control: The phase is selectable between 0 and 180 degrees.
  • Gain Factor: Gain Factor is a unique and patent-pending digital processing technology that allows more audible power to be delivered even when pushing the amplifier to its limit. Unlike all analog compensation techniques, Gain Factor interpolates and modifies the signal at the individual digital data level, enhancing smaller signals more and larger signals less without driving the amplifier into hard clipping. The result is more clean power, sooner on the volume knob. You can select a gain factor of 0dB, +6dB or +9dB.
Multi-Amp Installation: Because the above Bass Engine adjustments are all digital and discrete, two of these amplifiers can be used to power the two voice coils of a DVC woofer. Note: Technically this is true of any amp, but with analog adjustments an oscilloscope is needed to ensure the outputs are identical.
Amplifier ID: Alpine's RUX-4280 Remote Amplifier Control Center (RACC) will control up to eight V12 AccuClass-D amplifiers. For this reason each amp needs its own ID when more than one amp and the RACC are used.
Optional Remote Level Control: This amplifier's level can be controlled remotely with the optional RUX-4180 Subwoofer Level Control. Note: The RUX-4180 can only control one amplifier. For multiple amplifiers, the RUX-4280 Remote Amplifier Control Center should be used.
Turn On Delay: The amp's turn-on time is adjustable from 0 to 2 seconds in 0.2 second steps. This is useful for eliminating the loud "thump" that occurs when multiple amplifiers are turned on simultaneously.
Output Disable Mode: The Output Disable Mode turns off the power output of the amp while leaving the control functions active. This should be used when adjusting the DSP function. Only the power of the DSP circuit is on and in the current saving state. After making adjustments, the output disable mode should be turned off.
Memory: The settings on the amp can be stored in one of two memory slots to make it easy to return to your preferred values.
3-Way Protection Circuitry: This amplifier has a 3-way protection circuitry to guard against accidents and undesired operations. It includes protection for Short circuit, Over-voltage, and Thermal overload. When the amplifier goes into protection mode, the LCD display will show a Error code explaining the cause of the failure.
Battery (+12 V)/Ground (GND): The Battery and Ground terminals are gold-plated set-screw terminals that will accept up to 4 gauge wire. A 4mm Allen wrench is included to tighten/loosen the set screws.
Remote (turn-on): The remote terminal is combination gold-plated screw terminal that will accept a spade connector up to .35" wide on top of the terminal, or set-screw terminal that will accept up to 10 gauge bare wire into the front of the terminal. A Phillips-head screwdriver (not supplied) is required to tighten/loosen the set screw.
Speaker Output: The speaker terminals are gold-plated set-screw terminals that will accept up to 8 gauge wire. A 2.5mm Allen wrench is included to tighten/loosen the set screw.
RCA Input/Output: The amplifier includes gold-plated RCA line input jacks (there is no speaker-level input) and gold-plated RCA pre-out jacks.
Controller: The amp has a 7-pin female DIN jack for connection to the RUX-4280 Remote Amplifier Control Center (RACC) or the RUX-4180 Subwoofer Level Control.
Specifications
CEA-2006 Compliance: The specifications given by Alpine for the MRD-M501 amplifier comply with the new CEA-2006 Amplifier Power Standard from the CEA (Consumer Electronics Association). All manufacturers who comply with the standard can display the CEA-2006 logo on their product.
RMS Power Rating (measured at 14.4V):
  • Into a 4-Ohm Load: 275 watts x 1
  • Into a 2-Ohm Load: 550 watts x 1
RMS Power Rating (measured at 12.0V):
  • Into a 4-Ohm Load: 225 watts x 1
  • Into a 2-Ohm Load: 425 watts x 1
Note: Minimum impedance is 2 Ohms.
and they are 2 x type r alpine 12' subwoofers i'll have to pull them out of the banpass box to find the model number I'll list those specs asap.
I am not sure what settings are right for the amp
thank you for your time
Date Posted: October 01, 2007 at 10:44 PM
ok I found specs on the subs...  and have another question which should i use banpass or sealed for best quality sound in an 88 ford thunderbird trunk...
sub specs as follows:
Product MPN
MPN swr-1241d
Key Features
Car Speaker Type  posted_image
Component
Elements  posted_image
1-Way
Car Speaker Function  posted_image
Subwoofer
Size 12.00"
Nominal Power Handling  posted_image
300 Watt RMS
Powered  posted_image
Non-Powered
Technical Features
Peak Power Handling 1000 Watt
Frequency Response 24 Hz - 2 kHz
Sensitivity 87 dB
Impedance 4 ohm (Dual Coil)
Components
Woofer Material  posted_image
Composite
Surround Material  posted_image
Santroprene
Mounting
Enclosure  posted_image
Non-Enclosed
Top Mounting Depth 6.81 In.
Bottom Mounting Depth 7.50 In.
Mounting Diameter / Length 10.81 In.
Miscellaneous
Product ID 20243827
Posted By: tcss
Date Posted: October 01, 2007 at 10:46 PM
You have 2 volt pre outs. Here ya go.
Input level switch on amp 1V-2.0V
Input mode 1+2
Level 2.0v
Gain 0db
Lp On
Freq. 80hz
Slope 24db
Subsonic On
Subsonic freq. 20hz
P Eq  On
P EQ Freq. 60hz.
Q Width 3
P Eq Level -3db
Bass comp On
Level Comp 1
Time Corrct Off
Phase 0
Let me know how it sounds and whether it needs to be tweaked. This should be a good place to start.
Bass
Posted By: tcss
Date Posted: October 01, 2007 at 10:52 PM
I always liked these subs in a sealed enclosure. Go to Alpines web sight to see specs. You have dual 4 ohm coils which is not the optimum set up for this amp. You need to series/parralell wire these two subs. Do a search on this sight to find out how.
Posted By: the12volt
Date Posted: October 01, 2007 at 10:58 PM
Posted By: tcss
Date Posted: October 01, 2007 at 11:05 PM
Thanks Volt
Date Posted: October 01, 2007 at 11:08 PM
You're welcome.
posted_image the12volt • Support the12volt.com
Date Posted: October 02, 2007 at 12:03 AM
thanks gentlemen I'll revise my settings and repost the results
Date Posted: October 02, 2007 at 12:10 AM
Also if this is not the optimum amp for these subs...  I work for circuit city I get huge discounts on kicker, Is there a specific kicker amp that would be more compatable to these subs?   Suggestions on wire gauge set up  for the system I already have?
