chrysler grand voyager
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=97730
Printed Date: March 25, 2026 at 3:00 AM
Topic: chrysler grand voyager
Posted By: sgbone
Subject: chrysler grand voyager
Date Posted: October 06, 2007 at 3:58 PM
This is a Uk British spec vehicle.
Grand Voyager : Radio problem. I have been to upgrade the radio and found a wire I do not know how to get around it. It goes into a very small white plug located at the top right (looking from rear of unit) I know if i connect it the steering wheel controls work and sound from the radio. But then if i disconnect it and turn the ignition off the steering wheel controls dont work and no sound comes from the radio, Plug it in again and all ok. Only thing is I want to change to a Pioneer radio, ?? Can anyone tell me ahet this wire is please.
from steve
I came, I saw, I wired it in,
Posted By: Velocity Motors
Date Posted: October 06, 2007 at 4:13 PM
??? That wire is the steering wheel control wire in the USA/Canadian model and when removed all you loose is your steering wheel control. The OEM amplifier wire is GREEN on the BLACK harness if it's pre-2002.
Posted By: sgbone
Date Posted: October 06, 2007 at 4:56 PM
Hi, thanks for the reply. There is only two green wires on the black ISO. both are speaker wires ? green and GREEN/ black.
The Steering wheel wire also makes the amplifer come on ? I checked with the factory radio and the Blue wire on the black ISO is the amplifer turn on wire. Im really confused ?
Date Posted: October 07, 2007 at 5:33 PM
??? Euro Dodge's are that much different than USDM/CDM vehicles? Would you be able to take a picture of the harness and post or email it to me ?
Date Posted: October 07, 2007 at 5:36 PM
Are you using a harness adapter for the installation ? From the sounds of the wire colors that your describing, your telling me the adapter colors and not the vehicle wire colors.
