4ohm woofer 8 ohm tweeter standard crosov
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98099
Printed Date: May 07, 2026 at 1:27 AM
Topic: 4ohm woofer 8 ohm tweeter standard crosov
Posted By: nu1995
Subject: 4ohm woofer 8 ohm tweeter standard crosov
Date Posted: October 18, 2007 at 11:43 PM
I have a set or mb quart refreince 6 1/2 components and I don't like the tweeters ( I want silk dome not alu of tita or what ever they are) i found a set of pioneer 2" tweeters that are 8 ohm. what will the effects be or will it matter. power wise 200 watts
Posted By: jmelton86
Date Posted: October 19, 2007 at 2:11 AM
The crossovers with the MB Quart set were designed *specifically for the tweeters (and woofers for that matter) that came in the component set. If you were to switch to the Pioneers, the crossover frequencies will be way out of whack.
https://www.the12volt.com/caraudio/cross.asp
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
Posted By: DYohn
Date Posted: October 19, 2007 at 10:17 AM
Using an 8-ohm tweeter in a crossover circuit designed for a 4-ohm tweeter will drop the crossover knee frequency by half.  Meaning, if the crossover was designed for 1800 Hz with a 4-ohm tweet, placing an 8-ohm tweet in its place will change the Xover frequency to 900 Hz.  This may be very bad for the tweeter - indeed it may damage it - and it will certainly destroy the designed blend between the tweeter and the woofer.  Also, most passive crossovers include attenuation and filter circuits to match the sound of the tweeter to the woofer, or to create the quality of sound desired from the tweeter.  Changing the tweeter will affect these things as well.
in short, don't do it.
