wirring 4 gauge to a 8 gauge amp post
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98199
Printed Date: April 18, 2026 at 3:01 AM
Topic: wirring 4 gauge to a 8 gauge amp post
Posted By: wlatino30
Subject: wirring 4 gauge to a 8 gauge amp post
Date Posted: October 22, 2007 at 8:34 AM
Currently i have an infinity basslink in the trunk of my 02 chrysler concorde lxi witch was given to me by one of my friends. i have 4 gauge power wire, and 4 gauge ground wire, wired to the amp. infinity basslink has a 30 amp fuse and is rated at 200 watts rms going to the enclosed 10inch sub. the basslink calls for 8 gauge wirring. i have wirred with 4 gauge for future aditions. my problem is that the rig i made to wire up the amp keeps comming loose from the ground. i took a 4 gauge ring terminal and cut off half of the ring to make it like a hook and inserted it in a 8 gauge ring terminal and crimped it in place. i dont want to change the power and ground down to an 8 gauge set up.
if i use a distribution block to step down to an 8 gauge. one for power and one for ground will this affect anything?
2002 chrysler concorde lxi wiith premiun infinity system
Posted By: stevdart
Date Posted: October 22, 2007 at 8:24 PM
That's fine and is the normal way to do it.  Use a fused distro for the power side as 8 gauge will accept less current than your main 4 gauge.  Use a non-fused distro for the ground.
