bigger wire guage on a amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98361
Printed Date: April 18, 2026 at 7:27 AM
Topic: bigger wire guage on a amp
Posted By: still_walkin
Subject: bigger wire guage on a amp
Date Posted: October 27, 2007 at 8:30 AM
I have a question about amp wiring. All amps have the suggestion and max wiring guage and it states not to use a larger size. My question is if you use a reducer on a amp to fit bigger wire will it damage your amp or give it an extra boost is it recommended. Ex. I have (2) 200watts peak amps 4 guage max and (1) 3200 peak amp 4 guage max. Now if I rewire them to zero guage (power/ground) what will happen also is it worth it?
------------- 1993 sdv
Alpine 4x6 6x9 5 1/4 swr-10d4
alpine v60
12.5 VGA flip down
Nettop pc w/10" touch screen
78nova
5-re audio 5x7 ,10" sub &
Xtx-500.5
Posted By: haemphyst
Date Posted: October 27, 2007 at 9:30 AM
Are these your present amplifers that state NOT to use a larger gauge wire? I've never seen that ever in any amplifier manual stating "do no use a larger gaufge wire". Nothing will happen, but (other than appearance) you'll gain little to nothing, performance-wise. Your price to performance ratio will be completely SHOT!
NOW, if (as in one case, the Orion HCCA225, which came with a #10 power wire, pre-attached) the amplifier comes with or recommends a wire gauge that is too small, if you replace it to a proper gauge, you WILL gain...
Do the math:
200 watts (peak) = roughly 100 watts RMS 100 WRMS/14.4=6.9A
3200 watts (peak) = roughly 1600 watts RMS 1600 WRMS/14.4=111A
CERTAINLY the two 200 watt amplifiers could be run together off of a single 10 gauge, but the 4 gauge recommendation for the 3200 watter is appropriate, and you'll gain little to nothing, ESPECIALLY jumping all the way to a 1/0 cable. I am figuring 100% efficiency, but even at 50%, you won't get much...
------------- It all reminds me of something that Molière once said to Guy de Maupassant at a café in Vienna: "That's nice. You should write it down."
Date Posted: October 27, 2007 at 10:41 AM
Thanks its was a crazy idea and I wondered if it would work or not. So basically I would wasting my time
alpine v60
12.5 VGA flip down
78nova
Xtx-500.5
