kenwood kac 9102d amp not working
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98491
Printed Date: March 25, 2026 at 4:28 AM
Topic: kenwood kac 9102d amp not working
Posted By: itsmejaytee
Subject: kenwood kac 9102d amp not working
Date Posted: October 31, 2007 at 1:19 PM
My amp does not work due to my stupidity. Power, ground, fuses and everything work perfectly fine, however i managed to spark the inside of the terminal and something inside shorted. now it wont turn on with everything connected. can anyone help me troubleshoot this?
Posted By: haemphyst
Date Posted: October 31, 2007 at 2:29 PM
Huh? Sparked? Sparked what? Which terminal? The speaker output terminals? If that's the case, you probably fried something, and you're gonna need to have it repaired.
You COULD try to disconnect all of the power cables, then reconnect them, see if that'll reset some protection circuit, but that's about as far as you'll be able to go, short of opening the amplifier, which I do not recommend.
Posted By: i am an idiot
Date Posted: October 31, 2007 at 8:24 PM
Have you used a volt meter to make sure you have power getting to the amp?
Date Posted: October 31, 2007 at 10:14 PM
yea pretty much... i fried the insides and i hooked up a spare amp too the same cables and they work fine. damnit i was hoping that you guys would know what fried inside. thanks for the reply though guys, i appreciate it
