dyna quest amplifiers
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98761
Printed Date: April 02, 2026 at 7:42 PM
Topic: dyna quest amplifiers
Posted By: melea
Subject: dyna quest amplifiers
Date Posted: November 08, 2007 at 7:05 AM
i have a dyna quest power amplifier and set it in my car an old model mitsubishi lancer,but my problem is everytime switch it on to listen to a radio in about 5 minutes it will shutdown and before that i have power sub speaker sony explode 1500 watts that connect to my amplifier and my question is what is the problem with that
Posted By: haemphyst
Date Posted: November 08, 2007 at 9:56 AM
If I understand your question compleletly, it could be many things... Low voltage, overheating, too low an impedance connected to it, defective amplifier...
What have YOU done to troubleshoot it?
------------- It all reminds me of something that Molière once said to Guy de Maupassant at a café in Vienna: "That's nice. You should write it down."
Posted By: coppellstereo
Date Posted: November 08, 2007 at 3:39 PM
Look to see if there are any lights lit on the amplifier when it shuts down. I bet it is going into protection from overheating. Check your ground and your impedance load. As well as punctuation.
