wiring harness, 02 cavalier
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98911
Printed Date: May 07, 2026 at 4:03 AM
Topic: wiring harness, 02 cavalier
Posted By: longfellow420
Subject: wiring harness, 02 cavalier
Date Posted: November 12, 2007 at 2:15 PM
I'm going to be replacing a head unit in an 02 Chevy Cavalier and the only wiring harness I can find had a data retention cable on it.  Can you bypass the harness, hard wire it and not use this cable, or do you have to rewire the entire car to bypass it.  Any help would be appreciated.
Posted By: swerve
Date Posted: November 12, 2007 at 2:19 PM
you can use the metra 70-2003, only thing you loose is door chime.
git yer swerve on!
Posted By: warriorcookie
Date Posted: November 13, 2007 at 9:21 AM
Also with the 70-2003, you have to mount the factory head unit somewhere else (I usually put it behind the trunk carpet in the rear drivers quarter panel). You need to retain the data aspect in your car. If you try and "hard wire" it you loose door chime, dome light, and airbags.
Just use the GMRC01 (from metra), it's got the built in module, it'll fit in your dash (no running harness into your trunk), and you retain everything (chime included).
Posted By: jrod83
Date Posted: November 13, 2007 at 9:43 AM
when you bypass it like swerve said you have to run your own ignition wire. ive only seen it done, ive never done it personally. Im not sure what they tap into on those cars...
MECP Certified
I am the loudest and proudest member of the Fighting Aggies Class of '11 WHOOP!
SAW 'EM OFF!
