how to wire a dvc sub?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99461
Printed Date: April 08, 2026 at 12:08 AM
Topic: how to wire a dvc sub?
Posted By: chrisbean
Subject: how to wire a dvc sub?
Date Posted: November 28, 2007 at 10:17 PM
Ok, I've read alot here on how to wire DVC subs till I'm finally confused! I have two 12" 4 Ohm DVC subs that I want to wire down to 2 Ohm to get the most from my amp. Is this the best way to do it...
Sub wire diagram.
WIll this get the most from my amp since it down to 2 Ohm? Will it let my subs get handle the most power from the amp or just half? It's a 1 or 2 channel amp-whatever i want. Or would it be better a different way as in run both channels and wire them down to 2 ohm?
Date Posted: November 28, 2007 at 10:21 PM
sorry about this..forgot this page....
2 channel sub amp diagram
Posted By: stevdart
Date Posted: November 28, 2007 at 10:35 PM
Yes, diagram #2 shows the configuration that will put a 2 ohm load on the amp.  4 ohm impedance bridged across two channels = 2 ohm per channel.  That's a 2 ohm load and your amplifier will output at its fullest.  The output is identical to running 2 ohm loads onto each channel separately (as seen in Crutchfield's diagram).
Look at your amplifier manual, at the output ratings.  What is the output at 2 X 2 ohms (stereo)?  What is it at 1 X 4 ohm bridged (mono)?  Are they not the same power output?
Posted By: jmelton86
Date Posted: November 28, 2007 at 11:11 PM
What is the model # of your amp? (hopefully he wasn't referring to both pairs of output terminals on a mono amp when he said he's got a 1 OR 2 channel amp)
Let us know what the model # of your amp is and we can help you further...
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
Date Posted: November 28, 2007 at 11:13 PM
Yeah ,they're the same 2x 2 ohm as 1x 4ohm. So I guess I'll stick to the 2 channel then? I just wasn't sure if 2 channels were better or just one channel...and how to wire them as well. Thanks a bunch!!
Date Posted: November 28, 2007 at 11:18 PM
Oh...one more thing. When an amp states something like 300 x 2 does that mean 300 watts into each channel or 300 divided by two = 150 into each channel?
Date Posted: November 28, 2007 at 11:42 PM
Didn't see your post till just now Jmelton86. Don't laugh..it'sa Ultra linear 2 channel that's bridgable to one channel (1600 watt max-yeah probaly not) BUT even cheep amps work.....posted_image Crappy amp (FREE) but for free.The guy next door gave it to me,bought it for his son but he died in a car wreak.But I'm pretty sure a mono amp is one channel in? one channel out? correct?
And these are my subs Polk Audio sr124 But I didn't pay near that price for both!
I did have these MA Audio HK12x2 But someone stole them from my garage....posted_image
Date Posted: November 29, 2007 at 12:04 AM
Your link to the amp doesn't work. Here's one: https://www.ultralinear.com/index.cfm/Mobile_Audio_Amplifiers_Series_2/fuseaction/ViewProductDetails/ProductID/3,3700906
It claims 800Wrms x 2 @ 2ohms, but I couldn't find any info on fuse(s) size. How many fuses does it have? What ratings are they for?
But yeah, you'll want to wire each sub to 2ohms, and put one on each channel. BTW, 300 x 2 means 300 x 2 (600 x 1).
Big3 in 1/0G
1/0G to GTO14001
Date Posted: November 29, 2007 at 12:08 AM
It has 4 25 amp fuses. I know that that means something but not real sure as in how powerfull it is. And yeah your link is to the right amp.Sorry about the link not working and I'm sure you had to search for it.I had to as well since I don't have the manual with me at the moment.
Date Posted: November 29, 2007 at 12:20 AM
100amps worth of fusing, alright. Simple math (gotta love simple mathposted_image) tells us that 100 (fuses) x 14.4 (voltage) = 1440. Take away about 35% for efficiency and you get 1400 x .65 = 936 watts.
That amp will give each sub about 468watts RMS. They call for 700Wrms, but in a ported box, they'll get loud enough for most (me, anyways!).
Oh, and I bet they sound WAY better than those MA's you had before. Try not to let these ones get gotten!
Big3 in 1/0G
1/0G to GTO14001
Date Posted: November 29, 2007 at 12:24 AM
They won't get them this time. Gotta good dog..wife has a walking dustmop..plus I have a good alarm on my jeep as well. But I did see this one that shoots fire from under the car...Hummm....Thanks you all for the help!!
