mbz 1992 300e amp bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99685
Printed Date: April 09, 2026 at 6:40 PM
Topic: mbz 1992 300e amp bypass
Posted By: mwelby
Subject: mbz 1992 300e amp bypass
Date Posted: December 05, 2007 at 12:33 PM
I am looking to install new sony head unit in 1992 MBZ 300E. Ordered unit form Crutchfield and was told I was told I would have to rewire all the speakers directly form new head unit because of ground problem. I this correct ? I thought I remembered doing one of these before and that you could just go to output side of amp in trunk area to connect speakers or possibly connect at fader near center console. Any input on installation in this vehicle would be helpful. The existing system is stock Becker radio / cassette, system 1432 I believe.
Posted By: tcss
Date Posted: December 05, 2007 at 2:19 PM
If you have a thumbwheel fader in the console I don't believe there is an amp. See if there are male/female speaker "T" connectors behind the deck. If there are, separate them. One set should go to the front speakers while the other should go to the rears via the fader.
There is no such thing as free installation!
Posted By: mwelby
Date Posted: December 05, 2007 at 3:33 PM
Thanks for the response, this vehicle does indeed have amp in right rear trunk area as I just looked at it. Amps and tuner are all located here. Anyone have any idea how and where to bypass these.
Posted By: tcss
Date Posted: December 05, 2007 at 4:36 PM
If it's a high level input you can just connect amp input output leads. If not, you need to run wires to the trunk.
Posted By: mwelby
Date Posted: December 05, 2007 at 6:51 PM
Thanks again, what I really trying to do is get specific information on color codes and location of speaker leads so I can bypass factory system.
Posted By: mwelby
Date Posted: December 06, 2007 at 11:40 AM
No one has ever worked on this car?
Posted By: dwarren
Date Posted: December 06, 2007 at 12:58 PM
Usually I just figure out the wiring as I go, with a speaker popper...Too many vehicles to keep track of.
