incorporating turn/brake lights
Forum Name: Motorcycle Electronics
Forum Discription: Installing Stereos, Alarms, Remote Starters, Lights, Garage Door Openers and other electronics on motorcycles.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=11704
Printed Date: May 08, 2026 at 5:29 PM
Topic: incorporating turn/brake lights
Posted By: jsmith
Subject: incorporating turn/brake lights
Date Posted: March 31, 2003 at 11:44 PM
     I have a 1997 gsxr750 with dual brake lights.I want to take out the factory rear turn signals to add on a stealthier rear end. Now I need to know if i can incoorporate my turn signals in with my brake lights. To be more specific here is how I would like them to work. When the left blinker is on i need the left brake light to flash and the right brake light to be on solid. When the right blinker is on i need the right brake light to flash and the left brake light to be on solid. These are dual filiment bulbs. There is one ground wire, a 12v parking light wire, and a 12v brake wire. All three wires split into two, one of each to each bulb. The turn signals each have a ground and a wire that only pulses 12v
Justin Smith
Posted By: sufferrar
Date Posted: April 01, 2003 at 4:53 AM
Sounds cool ...I would like to know how to do it too...
"I'm So Loud It Hertz"
Posted By: Ronald Mark
Date Posted: April 07, 2003 at 5:01 PM
Ok, you will need this convertor (DT18130), or one like it. From a this site:
Convertor
Here are instructions for a bike, it will be similar on your car.
conversion
Questions?
