12v battery into a 6v system?
Forum Name: Motorcycle Electronics
Forum Discription: Installing Stereos, Alarms, Remote Starters, Lights, Garage Door Openers and other electronics on motorcycles.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=52784
Printed Date: May 07, 2026 at 4:50 PM
Topic: 12v battery into a 6v system?
Posted By: outerfroggy1
Subject: 12v battery into a 6v system?
Date Posted: March 29, 2005 at 6:35 AM
not exactly car related but i figured someone in here would have some ideas. i am about ot purchase a 1975 suzuki rv90 dirtbike, whitch runs on a 6 volt electrical system. there is no electric start so the battery only handles the lights/blinkers as far as i know. what i would like to to is find a way to put a 12 volt battery in the bike and use some sort of regulator to reduce the voltage to 6 volts heading into the bikes harness. this way i can still use 12 volt accessories off the battery. is this possible? i dont mind using a battery charging unit instead of the bikes coil to charge the battery when its in storage. anyone have any ideas? here is a diagram of the harness if it is of any help
Suzuki RV90 Wiring Diagram
Posted By: DYohn
Date Posted: March 29, 2005 at 2:47 PM
I'd just install a second 6v battery.  Tap off between them for the standard bike electrical system, but across both in series to run any 12V additions.
Posted By: Thundervalley
Date Posted: April 01, 2005 at 2:03 AM
You'll fry the points and or condenser in it if you try running 12 volts to the whole bike.
