LED bulbs
Forum Name: Motorcycle Electronics
Forum Discription: Installing Stereos, Alarms, Remote Starters, Lights, Garage Door Openers and other electronics on motorcycles.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=79544
Printed Date: May 06, 2026 at 3:10 PM
Topic: LED bulbs
Posted By: paul k
Subject: LED bulbs
Date Posted: June 24, 2006 at 7:46 AM
hi
i change turn signal bulbs 1156 on my bike with led 12 v bulbs 1156       front bulb is not working and rear is flushing very fast      how do i make them work
Posted By: idealrides
Date Posted: June 25, 2006 at 11:55 PM
LED's are polarity sensitive... make sure the 1156 socket up front supplies +12v to the center contact. Also you need load equalizers (resistors) for your signals or you may be able to swap to an electronic signal relay.
