power antenna wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=100014
Printed Date: May 15, 2026 at 12:08 AM
Topic: power antenna wiring
Posted By: overland69
Subject: power antenna wiring
Date Posted: December 14, 2007 at 1:19 PM
1999 Mercedes S430, 2 pin plug. Power on one side and ground on the other - to go up Ground on one side and power on the other - to go down How do I immitate this action using a relay?
Posted By: howie ll
Date Posted: December 14, 2007 at 3:26 PM
Feed from antenna out on radio to 86, ground to 85, 12v+permanent to 87, down wire to 87a up wire to 30.
Posted By: i am an idiot
Date Posted: December 14, 2007 at 7:57 PM
Date Posted: December 14, 2007 at 8:00 PM
The above pic was drawn for another application Substitute the Positive from brake switch with the power antenna wire of the deck.
Posted By: howie ll
Date Posted: December 15, 2007 at 2:45 AM
Sorry I missed the whole point, first the factory antenna would have had built in relays, second you would need timers such as as 508d set for 4 secs, thirdly the last post is correct but I would substitute 2 x 508d's to stop overun when most has extended or retracted.
Date Posted: December 15, 2007 at 3:42 AM
The antenna in that car has limit switches mounted internally. Their purpose is to prevent overrun. Overland, in my picture, the left (To Motor Wire) has 12 volts on it when the radio is switched off. The right wire has ground on it.
Posted By: howie ll
Date Posted: December 15, 2007 at 4:08 AM
Yes but are we talking about the factory original? That used 2 relays and a timer circuit and it was always going wrong, replaced with a single 528t (not as I said earlier a 508d ) N.B. I think the limits were imposed by the timer, no mechanical limiter, thinks yes 2 relays required it's what DEI call a 5 wire solution but unlike door locks you need to hold on for a few secs each way, look add a thermal load cutout and you've just built a window closer! | |
