compustar timer add on to temp sensor con
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=100045
Printed Date: May 14, 2026 at 10:45 AM
Topic: compustar timer add on to temp sensor con
Posted By: lowradiation
Subject: compustar timer add on to temp sensor con
Date Posted: December 15, 2007 at 10:08 AM
I would like to hook a 556t programable timer to a compustar stater.The model # 1wam-s with a cm4200 contoller and has a temp sensor port which in default mode can be used to start the starter.Connector 5 has a 3 pin connector
(-) black pin 3
(temp) Brown pin 2
(+) gray pin 1
The wire from the 556t is a neg pulse,which pin would I use ?posted_image
thanks
Date Posted: December 15, 2007 at 10:10 PM
CONNECTOR 5 (Optional Temperature sensor)
PIN 1 Gray-12-volt (+) positive output. This wire will provide 12-volt (+)
positive to temperature sensor.
PIN 2 Brown-Temp sensor (-) negative input. This wire will activate remote start
when provided a (-) negative input. (Note: If vehicle is remotely started, a (-)
negative input will turn the vehicle off.)
PIN 3 Black-Temp sensor (-) negative ground output.
