1998 corolla starter disable hookup
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=100051
Printed Date: May 14, 2026 at 7:33 AM
Topic: 1998 corolla starter disable hookup
Posted By: briankp
Subject: 1998 corolla starter disable hookup
Date Posted: December 15, 2007 at 1:16 PM
I am new to this.
Does anyone have experience on hooking up a 1998 Corolla Starter disable using a Clifford Saber II alarm?
I am confuse as to which color of the wire I need to use from the Ignition harness to hook up the Relay?
Any help would be appreciated.
Posted By: dre187
Date Posted: December 15, 2007 at 5:37 PM
your alarm should have a "ground when armed (-)" wire, orange in colour.  wire your relay as follows...
pin 85-     ground when armed (neg output)
pin 86-      +12v constant
pin 30-      key side of the starter wire
pin 87a-       motor side of the starter wire
pin 87-  empty
i believe the starter wire in the corolla is RED and it is at the ignition harness
Posted By: briankp
Date Posted: December 18, 2007 at 2:32 PM
Will this hookup be better because it only works when the key is turned on momentary.  If Alarm is activated from 85, then 87a will be disconnected.  The Starter will not start as a result.
Thanks for your review and opinion!
87 - No connection
86 and 30 is connected together and go to the Ignition Switch.
87a - goto the Starter Solenoid ( motor side)
posted_image
