Locating Ground When Running
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=100100
Printed Date: May 13, 2026 at 2:48 PM
Topic: Locating Ground When Running
Posted By: jamball
Subject: Locating Ground When Running
Date Posted: December 16, 2007 at 5:40 PM
I need to find a ground when running for the second ignition relay in a 1999 Yukon for my remote starter.
Posted By: sparkie
Date Posted: December 16, 2007 at 6:05 PM
The remote starter supplies a ground out when running circuit. Use this to trigger one side of the relay coil to hook up a 2nd ignition relay. Check your install manual. Some units label it as a 2nd ignition output. It will be a negative output used to power a relay when the remote starter is activated.
sparky
Posted By: Twelvoltz
Date Posted: December 16, 2007 at 6:07 PM
What is the make and model of your remote starter?
If it is a DEI unit the Ground While Running will be labeled as 'status output'. Most systems offer an additional low current output for that second ignition relay.
Posted By: jamball
Date Posted: December 16, 2007 at 6:22 PM
it is a compustar and I have looked through the manual and can not find a second ingnition output. There is however a status output. Any ideas?
Posted By: sparkie
Date Posted: December 16, 2007 at 6:27 PM
I have only done one Compustar unit and it had outputs for 2nd ignition, start and accessory. They aren't in the main power plug, but in another plug and are thin wires. They are only used to ground relays. The status ouptut I believe is for a LED. If it only goes to ground during the remote starter cylce and is capable of 250 ma, you could use it.
sparky
Posted By: jamball
Date Posted: December 16, 2007 at 6:38 PM
There is another plug that lists light, status, ingnition, accessory, & starter ouput all with 250mA. So I can use anyone of these?
Posted By: tedmond
Date Posted: December 16, 2007 at 7:25 PM
from compustar, take ignition ouput MAX 250 mA, connect it to a relay like so.
85 - Constant 12volts
86 - ignition output from compustar brain (250mA)
87 - High current constant 12volt source eg @ ignition harness
30 - to second ignition wire on yukon.
good luck !
Posted By: KarTuneMan
Date Posted: December 16, 2007 at 10:01 PM
Status output IS ground while running. It's active 1 second before remote start, and 1/2 second after shut down.
Used for triggering a bypass module!
Posted By: jamball
Date Posted: December 17, 2007 at 8:11 AM
Thanks for everyones help. I think I have it now.
Posted By: jamball
Date Posted: December 17, 2007 at 8:35 PM
I tried using the Ingnition output but it would not activate the relay. So I tried the status output and it DID activate the relay. Is there any reason that the status output could not be used for both the sercuity bypass module and to activate the relay for the second ignition wire? also is it posiible that I blew a fuse internally in the compustar unit itself and that is why the ingnition output wouldn't work?
Posted By: tedmond
Date Posted: December 17, 2007 at 9:34 PM
test the output of it with a volt meter, see if the output is giving anything. if not it must be a programming issue. i dont remember if compustar requires programming for optional ignition or acc. I kno on prostart, they are 5th relay, and a jumper will do the work for you.
Posted By: musikar
Date Posted: December 18, 2007 at 10:53 PM
In the small connector there as a son status = black, green = ing 2, red / black = 2 start, white / black = 2 accessory, green / white light parking neg =
