infiniti i30 alarm power door wires
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=100281
Printed Date: May 02, 2026 at 11:45 PM
Topic: infiniti i30 alarm power door wires
Posted By: hyperwhite
Subject: infiniti i30 alarm power door wires
Date Posted: December 20, 2007 at 10:23 PM
I have a infiniti i30 1996 and going to be installing an alarm system with keyless entry. When I was looking at wiring diagrams, it states that the power door lock wire is located in drivers door at switch. Are you kidding me? So I have to run the wire from my dash to the driver's door. Is there a better way? Please any help will be appreciated. Thank you Power Door (Lock) Wiring Diagram for [Negative (-)] Door Lock | lt. GREEN/ red | Negative (-) | in drivers door at switch | Power Door (Unlock) Wiring Diagram for [Negative (-)] Door Unlock | GREEN/ YELLOW [1] | Negative (-) | in drivers door at switch |
Posted By: enice
Date Posted: December 20, 2007 at 10:26 PM
Thats what i did to a 98 i30 last week...no biggie To test the wires you may need turn the key in the door cyllinder to get a reading.
Posted By: Twelvoltz
Date Posted: December 20, 2007 at 10:29 PM
Nope, you have to run into the doors on this one and remember to set your unit to double pulse for unlock. ------------- Installer, IT support, and FFL. I need less hobbies.
Date Posted: December 20, 2007 at 10:45 PM
damn. I hate running long ass wires. Thanks for the reply.
Posted By: Chris Luongo
Date Posted: December 21, 2007 at 10:10 AM
Yeah, I've never been able to find them on the inside on those cars.
Don't forget that on the car's body, just below the rubber boot for the wiring, is an unused black plug. You can run your wires through there, to make things a little easier.
I would suggest making your connections right at the power window switch. That way, in the future, if there's a problem you have to fix, you can just pop out the window switch, instead of taking the whole door panel off again.
Date Posted: December 21, 2007 at 9:48 PM
Thanks for the advice. I'll keep that in mind.
