92 civic, removed alarm, problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=100420
Printed Date: May 12, 2026 at 6:22 PM
Topic: 92 civic, removed alarm, problems
Posted By: i8umup
Subject: 92 civic, removed alarm, problems
Date Posted: December 25, 2007 at 5:28 PM
i have a 92 civic which i just got the prior owner put in a ungo ms850 alarm. i have had nothing but problems with it so i decided to remove it no when i turn my headlights on the car powers up it does not start but the fuel pump and all that cycles.. also i cant get the car to shut off when the key is off unless i turn the headlights off or turn the hazzard lights off/on does this make any sence did i miss a part of the alarm? please someone give me some assistance here.
Posted By: ringojam
Date Posted: December 25, 2007 at 7:49 PM
The ignition was not rewired properly? Check te wiring section and make shure the color codes are correct.
Jamaica home of the worlds fastest man.
Posted By: dj hellfire
Date Posted: December 25, 2007 at 8:00 PM
Exactly!  Make sure you removed all of the added aftermarket wiring.  Then just make sure all the stock wires were reconnected properly and not crossed.  Sounds like your parking lights or low beam lights are somehow wired to the ignition wire that power the fuel pump when the key is turned to the run position.  Make sure you accessory wire/s isn't connected to the ignition wire/s.
Posted By: perly
Date Posted: December 25, 2007 at 8:02 PM
you definetely have some crossed wired in your ign wires. sounds like you have your parklights tied into your ign/acc. get a meter and check that all wires are hooked up properly
Posted By: csnut18
Date Posted: December 26, 2007 at 3:10 AM
Also make sure you removed any starter kill relays. Their might be one hidden and still wired up. This actually happened to me once hehe.
