passive arming viper 771vx
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=100421
Printed Date: May 12, 2026 at 7:18 PM
Topic: passive arming viper 771vx
Posted By: babyboyyn3
Subject: passive arming viper 771vx
Date Posted: December 25, 2007 at 7:01 PM
Hello Good People,
Can someone please provide step by step instructions on how to activate passive arming on the Viper771XV?
It's not in the manual
Thanks...
babyboy
Posted By: ringojam
Date Posted: December 25, 2007 at 7:37 PM
Its in the instllation manual. Take it back to yr installer and let them program it for you.posted_image
Jamaica home of the worlds fastest man.
Posted By: Twelvoltz
Date Posted: December 25, 2007 at 8:55 PM
Ringojam is correct, if you had it professionally installed they should make this change for you free of charge.
If you want to tackle it yourself the installation manual is in the downloads section: link. System features learn routine starts on page 39, passive arming is feature 1-1.
Open door, key on then off, hold programming button till you hear single chirp. Release programming button, press programming button 2x holding the button down on the second press (this selects feature menu 1 option 1) when the system chirps once again press unlock on the remote, the system will chirp two times to confirm your setting.
Date Posted: December 25, 2007 at 9:32 PM
Thanks I did it..... But I am wondering ...I thought along with passive arming when this happens the car should lock as well. It sets the alarm but will not automatically lock the car.
babyboy
Date Posted: December 25, 2007 at 10:01 PM
Feature 1-5: Passive Locking
I do not recommend turning this on, the reason they have it separate is the likely hood of locking your keys in the vehicle.
Posted By: tedmond
Date Posted: December 25, 2007 at 10:11 PM
it should arm and lock. there might be an issue with your unit?
Posted By: another-kelly
Date Posted: December 25, 2007 at 10:48 PM
what he said.
seems like i've been doing that a lot lately
