| Print Page | Close Window |
2007 trailblazer ls car starterPrinted From: the12volt.comForum Name: Car Security and Convenience Forum Discription: Car Alarms, Keyless Entries, Remote Starters, Immobilizer Bypasses, Sensors, Door Locks, Window Modules, Heated Mirrors, Heated Seats, etc. URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=100467 Printed Date: May 13, 2026 at 5:12 PM Topic: 2007 trailblazer ls car starter Posted By: FrozenTundra Subject: 2007 trailblazer ls car starter Date Posted: December 27, 2007 at 7:19 AM Looking for the wire information on a 2007 trailblazer ls with factory remote keyless entry. Is it the same a a 2006?? Also I would like to hook up the locks so I only need on remote. Is there a specific module needed to interface the system?? I would rather not use a ton of relays if a module exists.
Replies: Posted By: Twelvoltz Date Posted: December 27, 2007 at 7:38 AM Audiovox Lists:
#510395: 2007 CHEVROLET TRAILBLAZER 4DR SUV WITH 5.3L ENGINE AND STANDARD AUDIO SYSTEM Audio/Mobile Video WIRE COLOR POLARITY LOCATION Battery ORANGE (+) RADIO HARNESS Accesory ORANGE (DATA) RADIO HARNESS THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE. Ground BLACK/ WHITE (-) RADIO HARNESS LF Speaker (+) TAN THESE WIRES ALSO GO TO THE FRONT LEFT TWEETER LF Speaker (-) GRAY RF Speaker (+) LIGHT GREEN THESE WIRES ALSO GO TO THE FRONT RIGHT TWEETER RF Speaker (-) DARK GREEN LR Speaker (+) BROWN LR Speaker (-) YELLOW RR Speaker (+) DARK BLUE RR Speaker (-) LIGHT BLUE Steering Cntrls OPTIONAL THIS VEHICLE MAY BE EQUIPPED WITH ONSTAR® AND MAY LOSE DOOR CHIME AND OTHER VEHICLE MONITORING FUNCTIONS WHEN OEM RADIO IS REPLACED. USE PROPER INTEGRATION PIECE TO MAINTAIN THESE FEATURES. Speed Cntrl OPTIONAL Radio Security YES Security WIRE COLOR POLARITY LOCATION Battery RED OR RED / WHITE (+) AT IGNITION SWITCH HARNESS Ignition 1 PINK (+) AT IGNITION SWITCH HARNESS Starter 1 YELLOW (+) AT IGNITION SWITCH HARNESS All Door Trigger GRAY/BLACK (-) AT VEHICLE REAR FUSEBOX UNDER LEFT REAR SEAT TO AVOID THE DOMELIGHT DELAY FUNCTION, USE INDIVIDUAL DOOR TRIGGERS AND DIODE ISOLATE EACH WIRE, Domelight Super GRAY/BLACK (+) AT VEHICLE REAR FUSE BOX UNER REAR LEFT SEAT LF Latch GRAY/BLACK (-) IN THE DRIVERS DOOR RF Latch BLACK/ WHITE (-) IN THE PASSENGERS DOOR LR Latch LIGHT BLUE/BLACK (-) IN THE PASSENGERS DOOR RR Latch LIGHT GREEN/ BLACK (-) IN THE PASSENGERS DOOR Trunk Trigger PINK/BLACK (-) AT MODULE IN REAR HATCH VIOLET (-) WILL MONITOR THE GLASS AT THE MODULE IN THE REAR HATCH Hood Trigger PINK/BLACK (-) ON LEFT INNER FENDER NOT ON ALL MODELS Alarm Disarm LT. GREEN (-) IN DRIVERS DOOR AT MODULE Parking Lights GREY/BLACK (-) AT SWITCH OR BCM TAN PLUG PIN E5 Low Crr Pk Lights GRAY/BLACK (-) AT VEHICLE LIGHT SWITCH HARNESS Data Bus VIOLET (DATA) AT PIN 2 OF THE DIAGNOSTIC CONNECTOR UNDER THE DRIVERS SIDE DASH Convenience WIRE COLOR POLARITY LOCATION Headlights-Lo WHITE (-) AT VEHICLE LIGHT SWITCH HARNESS LF Pk Lt Bulb BROWN (+) AT FRONT LEFT PARKING LAMP RF Pk Lt Bulb BROWN (+) AT FRONT RIGHT PARKING LAMP LR Pk Lt Bulb BROWN (+) AT REAR LEFT TAIL LIGHT ASSEMBLY RR Pk Lt Bulb BROWN / WHITE (+) AT REAR LEFT TAIL LIGHT ASSEMBLY All Hazrd Lights WHITE (-) AT VEHILCE HAZARD SWITCH LF Hazrd Bulb LIGHT BLUE (+) AT FRONT LEFT TURN LAMP RF Hazrd Bulb DARK BLUE (+) AT FRONT RIGHT TURN LAMP LR Hazrd Bulb LIGHT BLUE (+) AT REAR LEFT TAIL LIGHT ASSEMBLY RR Hazrd Bulb DARK BLUE (+) AT REAR RIGHT TAIL LIGHT ASSEMBLY Wipers-Lo PINK (+) AT VEHICLE WIPER CONTROL SWITCH Wipers-Hi DARK BLUE (-) AT VEHICLE WIPER CONTROL SWITCH Parking Brake LIGHT BLUE (-) AT VEHICLE PARKING BRAKE SWITCH Seat Mem 1 WHITE (+) AT MODULE IN DRIVER DOOR Seat Mem 2 VIOLET (+) AT MODULE IN DRIVER DOOR Remote Start WIRE COLOR POLARITY LOCATION Battery RED OR RED / WHITE (+) AT IGNITION SWITCH HARNESS Ignition 1 PINK (+) AT IGNITION SWITCH HARNESS Ignition 2 WHITE (+) AT IGNITION SWITCH HARNESS Accessory 1 ORANGE (+) AT IGNITION SWITCH HARNESS Accessory 2 BROWN (+) AT IGNITION SWITCH HARNESS Starter 1 YELLOW (+) AT IGNITION SWITCH HARNESS Anti-Theft Type GM PASSLOCK II® ANTI-THEFT SYSTEM Anti-Theft Descript PASSLOCK II Key Sense LIGHT GREEN (-) AT THE STEERING COLUMN HARNESS Tachometer UNCOMMON COLOR (AC) ANY FUEL INJECTOR NOT PINK Speed Sense DK. GREEN / WHITE (AC) AT RADIO 24 PIN GREY PLUG OR PCM BLUE CONN. PIN 21 Parking Lights GREY/BLACK (-) AT SWITCH OR BCM TAN PLUG PIN E5 Low Crr. Pk Lights GRAY/BLACK (-) AT VEHICLE LIGHT SWITCH HARNESS Brake Lights WHITE (-) AT BRAKE SWITCH ABOVE BRAKE PEDAL Reverse Lights LIGHT GREEN (+) AT VEHICLE REAR FUSE BOX UNDER REAR LEFT SEAT Horn BLACK (-) BCM TAN CONN. PIN E12 ALSO BLACK (-) AT BCM MODUEL UNDER REAR LEFT SEAT Modules WIRE LOCATION Module 1 BCM-ATTACHED TO THE REAR FUSE BLOCK, BENEATH THE LEFT REAR SEAT Module 2 ECM-NEAR THE LOWER LEFT FRONT OF THE ENGINE Module 3 PCM-MOUNTED TO THE UPPER LEFT OF THE ENGINE Module 4 EBCM- FRONT DRIVER SIDE FRAME RAIL Doorlocks/Windows WIRE COLOR POLARITY LOCATION Databus Wire VIOLET (DATA) AT PIN 2 OF THE DIAGNOSTIC CONNECTOR UNDER THE DRIVERS SIDE DASH Power Unlock DATA BUSS SYSTEM (REV) AT MOTOR IN DOORS THE DOOR LOCKS IN THIS VEHICLE ARE MULTIPLEXED. WIRE AS A REVERSING POLARITY SYSTEM IN EACH FRONT DOOR OR ACQUIRE A MULTIPLEX INTERFACE ADAPTER FROM A SECURITY MANUFACTURER. PowerLock DATA BUSS SYSTEM (REV) AT MOTOR IN DOORS THE DOOR LOCKS IN THIS VEHICLE ARE MULTIPLEXED. WIRE AS A REVERSING POLARITY SYSTEM IN EACH FRONT DOOR OR ACQUIRE A MULTIPLEX INTERFACE ADAPTER FROM A SECURITY MANUFACTURER. Driver Mtr Unlock TAN (REV) AT THE DRIVERS DOOR MODULE IN THE DRIVERS DOOR 24 PIN CONNECTOR PIN B2 Driver Mtr Lock GREY (REV) AT THE DRIVERS DOOR MODULE IN THE DRIVERS DOOR 24 PIN CONNECTOR PIN B3 Pas Mtr Unlock TAN (REV) AT MOTOR IN DOOR Pas Mtr Lock GREY (REV) AT MOTOR IN DOOR LF Window Up DARK BLUE (REV) DRIVER DOOR MODULE LF Window Dn BROWN (REV) DRIVER DOOR MODULE RF Window Up LIGHT BLUE (REV) PASSENGER DOOR MODULE RF Window Dn TAN (REV) PASSENGER DOOR MODULE LR Window Up DARK BLUE (REV) REAR LEFT WINDOW SWITCH IN REAR LEFT DOOR LR Window Dn BROWN (REV) REAR LEFT WINDOW SWITCH IN REAR LEFT DOOR RR Window Up DARK BLUE (REV) REAR RIGHT WINDOW SWITCH IN REAR RIGHT DOOR RR Window Dn BROWN (REV) RERA RIGHT WINDOW SWITCH IN REAR RIGHT DOOR Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation. Pick up the GMDL-BP it does door locks, and passlock II. Very simple to install. ------------- Installer, IT support, and FFL. I need less hobbies. Posted By: FrozenTundra Date Posted: December 27, 2007 at 9:00 AM Thank you exactly what I was looking for!!!
Did you get that from a program or something like that?? Posted By: Twelvoltz Date Posted: December 27, 2007 at 9:03 AM Audiovox lists their information for free. If you go here just fill out the form and it will give you access to their tech site. techservices.audiovox.com.
------------- Installer, IT support, and FFL. I need less hobbies. Posted By: tedmond Date Posted: December 27, 2007 at 2:31 PM or you can go to www.scytek.net and download their wiring wizard. call them and activate it.
