05 infiniti qx56 door lock/unlock wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=100472
Printed Date: May 13, 2026 at 7:46 PM
Topic: 05 infiniti qx56 door lock/unlock wiring
Posted By: electriqtion
Subject: 05 infiniti qx56 door lock/unlock wiring
Date Posted: December 27, 2007 at 11:17 AM
Have anyone installed an alarm on a 2005 Infiniti QX56? I'm having a problem finding the correct wire for the door lock and unlock I used:
Power Lock blue - driver door module in door, pin 4
Power Unlock red (double pulse) - driver door module in door, pin 6
But can't seem to find those wires. Any suggestions? Also I wanted to connect the Hatch/Trunk release to an aux so that I can be able to release and open the back hatch from the remote. I followed the note, but the wire on the switch is giving me a + reading:
Trunk/Hatch Release yellow/brown or yellow/red - BCM to right of column, pin 30
Notes: For the power liftgate use blue/white (-) at the power liftgate switch on the dash.
Any help would be greatly appreciated.
------------- Electriqtion
Posted By: Chris Luongo
Date Posted: December 27, 2007 at 11:43 AM
You want to make the rear hatch go up and down with your remote, right? Then you'd use the blue/white at the switch, which is negative trigger, and no relay is needed.
There is no need to go into the door for locks. Use the search feature here...I think if you search for the words "nissan" and "bcm" you'll find it.
Posted By: big sexy lac
Date Posted: December 27, 2007 at 2:31 PM
The doorlock and unlock wires that you need are at the switch
------------- WELL?
