89 ranger doorlock interfacing
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=100655
Printed Date: May 12, 2026 at 1:51 AM
Topic: 89 ranger doorlock interfacing
Posted By: saskr
Subject: 89 ranger doorlock interfacing
Date Posted: January 01, 2008 at 6:55 PM
Good day folks, I tried the search function & also scrolled thru 10 pages before posting. We put a Prostart into an 89 Ranger but am having trouble sorting out the power locks. The wiring guide shows the wiring colors & location behind the drives headlight. But this truck does not use relays to control the actuator. Is there a module or other way to allow the remote start to control the door locks? THX, Cheers Rick
I used to have a handle on life, but it broke.
Posted By: Twelvoltz
Date Posted: January 01, 2008 at 7:06 PM
Since the vehicle does not have factory relays controlling the actuators you would wire them as a 5-wire setup. This diagram should clear things up for you.
Posted By: saskr
Date Posted: January 01, 2008 at 10:04 PM
Thx for the reply, by the looks of it I would have to wire the relay package inside the drivers door. Or could one make the connections @ the factory plugs behind the drivers headlight. Cheers Rick
Date Posted: January 02, 2008 at 7:14 AM
You can make those connections behind the headlight.
Posted By: autosound_30
Date Posted: January 02, 2008 at 10:13 PM
hi ,i would like to find the tach wire in a ford ranger 2007 from singapore,can anyone help? thanks
autosoundja
