2002 trailblazer, remote start, keyless
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=100657
Printed Date: May 12, 2026 at 2:52 AM
Topic: 2002 trailblazer, remote start, keyless
Posted By: jslayton
Subject: 2002 trailblazer, remote start, keyless
Date Posted: January 01, 2008 at 7:50 PM
I am installing a remote start system on my mom's car and was wondering what the best way to go about it was. I have seen where people have talked about using a GMDL BP module that makes bypassing the doorlock problem easier. If I do this, do I still end up having to run wires to each door individually? Also, is it worth getting this module for the trouble? Thanks in advance for your help.
Posted By: Twelvoltz
Date Posted: January 01, 2008 at 7:58 PM
The bypass module eliminates the need to go into the doors to interface with the door locks as well as bypassing the passlock system and interfacing with the factory alarm. That piece works very well and makes the installation on your truck very simple. I recommend using it.
------------- Installer, IT support, and FFL. I need less hobbies.
Posted By: jslayton
Date Posted: January 01, 2008 at 8:02 PM
Where does the module tie in?? Under the dash??
Date Posted: January 01, 2008 at 8:11 PM
Yes, right at the OBDII connector, pin 2, the purple wire. Have a look at the installation manual: here. ------------- Installer, IT support, and FFL. I need less hobbies.
Posted By: jslayton
Date Posted: January 01, 2008 at 8:21 PM
Excellent, thanks for the help. I will order the module and will probably have more questions once installing.
One more question before I go. By tying into pin 2, does that also take care of the passlock? Am I correct in thinking that this module doesn't have to be tied into the ignition switch at all?
Date Posted: January 02, 2008 at 7:25 AM
It does take care of the passlock via that single connection.
You do not have to do anything with the passlock wiring at the ignition switch, but the GMDL-BP does need to see ignition, constant hot, ground, and GWR which can be connected to the RS system during the bench wiring. ------------- Installer, IT support, and FFL. I need less hobbies.
