door lock actuator
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=100697
Printed Date: May 12, 2026 at 8:06 PM
Topic: door lock actuator
Posted By: frans-c
Subject: door lock actuator
Date Posted: January 02, 2008 at 8:19 PM
Sorry for the long tread, but I hope somebody can help me.
I replaced my car's vacuum central locking with an electric setup, using the basic aftermarket door lock motors - the reverse polarity ones with the blue and green wires. I also added one to my trunk lock. It's NOT a solenoid trunk popper, but simply locks and unlocks the trunk-lock mechanism.
Originally I had the trunk motor connected with the doors' wiring, so that it locks and unlocks whenever I lock and unlock the car. However, I recently added a relay so that I can control the trunk with one of my keyless entry's auxiliary channels. It works perfectly, the only thing being that I had to disconnect the unlocking wire of the trunk actuator from the doors' unlocking circuit. In other words, the trunk can now only be unlocked via the auxiliary channel of the keyless entry system. The trunk motor's locking wire is still connected to the doors' circuit, however.
What I'd like to accomplish, is for the trunk motor to still be unlocked with the doors. However, when I only want to get something from the trunk, I want to be able to use the auxiliary channel to unlock the trunk only.
I know I'll have to use a diode between the auxiliary relay's output terminal and the doors' unlocking terminal, with a cathode pointing towards the auxiliary relay's circuit. However, if I'm correct, the diode will prevent the trunk motor from locking, right?
What should I do to accomplish this?
------------- F R A N S
1985 Mercedes-Benz 230E
320 000 km / 199 000 miles
Full MB Service History
Posted By: KPierson
Date Posted: January 02, 2008 at 9:13 PM
If you put the diode from the unlock output to the trunk pop output things should work fine. Just make sure the strip is on the unlock side. Another idea would be to add an additional relay to the unlock output (unlock output to pin 85, ground to 86 and 30, and then tie 87 to the AUX out). The relay will provide isolation and make it impossible to have any issues. ------------- Kevin Pierson
Posted By: frans-c
Date Posted: January 02, 2008 at 9:45 PM
I really don't want to add another relay, there's not much space left for another one...
I'll try the diode fix, hope it works! ------------- F R A N S
