04 buick rendezvous
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=100881
Printed Date: May 01, 2026 at 7:42 PM
Topic: 04 buick rendezvous
Posted By: ziggyb222
Subject: 04 buick rendezvous
Date Posted: January 07, 2008 at 3:13 PM
Put an Ultrastart 1270 in a 04 rendezvous with the crimestopper(ifar) INT-SL module. I could not get the module to program. Tried another one and the same thing happened. I hold the button, plug in the first plug for power, then the second plug making sure it is right side up, then turn the ignition on and wait for it to flash, but it never does. Now using the old GM-SL was a snap... Any ideas why this will not program?
Posted By: moonliter
Date Posted: January 07, 2008 at 3:49 PM
did you use datalink connection or non datalink connection ?
Date Posted: January 07, 2008 at 4:50 PM
non data link... just like I always hooked up the GM-Sl modules.. those never failed me....
Posted By: Velocity Motors
Date Posted: January 07, 2008 at 9:41 PM
You have to HOLD THE PROGRAMMING button down while turning the ignition on. After the LED flashes then release the programming button and start the vehicle.
------------- Jeff
Date Posted: January 08, 2008 at 4:36 AM
Yes that is what I did.held the button all the way through.(pain in the butt ha ha ) but could not get the light to flash..
Date Posted: January 09, 2008 at 11:15 AM
Any other suggestions? Anyone else run into this problem???
Date Posted: January 09, 2008 at 12:24 PM
Do you have another module to try ?
------------- Jeff
Date Posted: January 09, 2008 at 12:38 PM
I also tried that.. same thing.. I was wondering if I might have to upgrade the software in it..
