04 crv remote start wont start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=100933
Printed Date: May 01, 2026 at 12:46 AM
Topic: 04 crv remote start wont start
Posted By: kemetuimay
Subject: 04 crv remote start wont start
Date Posted: January 08, 2008 at 3:23 PM
i had wire up most of the wires already and my car still won't start
it just crank but when i put the key in and remote start it then it work
can somebody help me on how i can make the remote start work without the key?
Date Posted: January 08, 2008 at 3:25 PM
i install a viper 791xv
Posted By: zboow
Date Posted: January 08, 2008 at 4:13 PM
That car requires a bypass module. Without one the car will not remote start.
Date Posted: January 09, 2008 at 1:02 AM
I finally figure it out thank you
since i install most of the wire to work but i didn't wire up the parking light because i didn't know how it work
can somebody help me with this
the wire from the viper say +/- for one wire but my car have two parking light wire for + and -  so which one do i wire it to
Posted By: brhaugen
Date Posted: January 09, 2008 at 6:21 AM
either will work
but make sure you set the viper output correctly for that wire's polarity (+ or -)
Posted By: tedmond
Date Posted: January 09, 2008 at 3:17 PM
the unit is defaulted @ postive (+) since most cars use it, but it is changeable to negative with a jumper.
Posted By: techman93
Date Posted: January 09, 2008 at 6:41 PM
invest in a digital multi meter or a computer safe test light. Check for (-) wire near steering column at light switch or (+) at driver kick panel or the fuse box.
Parking Lights
RED / BLACK     (+)     DRIVERS KICK PANEL
Low Crr. Pk Lights
BLUE             (-)     AT GREEN FACTORY ALARM PLUG IN DRIVERS KICK PANEL ALARM PLUG IS TO THE LEFT OF THE STEERING COLUMN TOWARDS THE FIREWALL
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
