2001 ford ranger
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101019
Printed Date: April 02, 2026 at 7:09 AM
Topic: 2001 ford ranger
Posted By: 1caraudioman
Subject: 2001 ford ranger
Date Posted: January 10, 2008 at 3:25 PM
I put a remote start on my truck i used a dei 556s-w the one with a blank key in it i cant for the life of me get the key to program?? any ideas? thanks chris
Posted By: another-kelly
Date Posted: January 10, 2008 at 6:12 PM
helps to tell us how you're trying to do it
Date Posted: January 10, 2008 at 7:04 PM
well on that bypass u stick one key in the theft light goes out then you do the other key i have done lots of these and cant figger out  why its not working?
Date Posted: January 10, 2008 at 9:18 PM
so you're powering up the remote start to simulate turning on the ignition the second time in order to program the 556s?
Posted By: ralphtonka
Date Posted: January 10, 2008 at 9:28 PM
start w 1st key, start w 2nd key, place new key in ign then hit rem start (assuming the starter is wired and programmed). then put the key in the bypass and ajust your ring
Date Posted: January 11, 2008 at 7:01 PM
this by pass has a uncut key in it im gonna try to ajust my ring
Date Posted: January 11, 2008 at 7:57 PM
rather than trying to program it via the ring, remove the key and hold the key next to the ignition as close as possible to the factory PATS ring when programming
Date Posted: January 11, 2008 at 10:07 PM
well i moved the ring it  worked great i have done a ton of fords and never had to move the ring ?guess theirs a first time for everything thanks for your input guys.chris
