2008 pathfinder
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101022
Printed Date: April 02, 2026 at 7:10 AM
Topic: 2008 pathfinder
Posted By: mikesloud
Subject: 2008 pathfinder
Date Posted: January 10, 2008 at 4:07 PM
2008 pathfinder doorlock wires i tried all sources cannot find right wires  i founda blue and purple at bcm but hooked direct and no luck on alarm. does it need a relay to isolate and amke stronger. i would rather confirm these are the right wires before i fry a bcm.
Never think you are done !
there is always more work!
Posted By: KarTuneMan
Date Posted: January 10, 2008 at 10:38 PM
LOCK GREEN/ purple Driver kick panel   -
 UNLOCK WHITE/ green Driver kick panel   -
You should not need relays.
