03 avalanche rap?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101026
Printed Date: May 14, 2026 at 11:30 AM
Topic: 03 avalanche rap?
Posted By: swatpilot
Subject: 03 avalanche rap?
Date Posted: January 10, 2008 at 6:02 PM
With all your help I installed my RS with allmost no problems.  The only thing I need is to be able to trigger the RAP so that if I dont get to my truck before the remote start turns off, that the radio just doesnt stay on.  Does anyone know the wiring color of the door trigger that turns off the RAP, and is it + or -.  thanks
Posted By: KarTuneMan
Date Posted: January 10, 2008 at 7:35 PM
What type of bypass did you use? And it doesn't shut the radio off?
The door pin is in the door grey/black (NEG)-
Date Posted: January 10, 2008 at 10:42 PM
I used a omega, and I tested the wires instead of waiting, but thank you KarTuneMan you were correct.  You the man.
Date Posted: January 10, 2008 at 10:44 PM
And no it didnt turn the radio off.
