02 toyota sienna door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101129
Printed Date: May 14, 2026 at 2:09 PM
Topic: 02 toyota sienna door locks
Posted By: bat9905
Subject: 02 toyota sienna door locks
Date Posted: January 13, 2008 at 9:28 PM
Hello I was wondering if any body could help me. I have a 2002 toyota sienna van and a prestige remote start keyless entry and the diagram says door lock wires are in passenger kick panel with lock being blue w white and unlock being blue with yellow. Is the unlock wire a bigger gauge wire because that is the only wire in the door lock wiring harness? I can get the doors to lock but not unlock
bat9905
Posted By: 519civiconair
Date Posted: January 14, 2008 at 4:18 AM
Have you tried probing the "suspect" wire with a DMM and hitting the unlock button?? Did you get a reading? if not keep looking.... if you did then.......
F.B.S.S air ride is the only way to roll
Posted By: KarTuneMan
Date Posted: January 14, 2008 at 8:57 AM
Look up higher in the kick. Abou5t as high as the ebrake pedal. Use the key in the door to test, not the switch.
Lock and arm is blue/white.Disarm is blue. set up with double pulse.
Posted By: Chris Luongo
Date Posted: January 14, 2008 at 10:25 AM
Just did one yesterday, and you can get them in the driver's kick panel, coming in from the door.
Posted By: bat9905
Date Posted: January 16, 2008 at 7:03 PM
Thanks for the help i found them and everything worked
bat9905
